I was looking at a vehicle that has an extremely sloppy shifter. So sloppy I was afraid to test drive it.
Eliminated the usual suspects: transmission mount is tight, rubber mounting blocks and shift platform are tight and the foam collar is tight. With a flashlight I was able to notice a tang on the bottom of the shifter assembly that was worn. Unfortunately, I have never seen a shifter style like this. It does not appear, so far as I am aware, in the factory manual or OEM diagrams. Trans is getrag 262. Shifter, is believed to be original early 73.
Anyone ever encounter this type of shifter? Any other vehicle/model use it? My first thought was to remove shifter and weld new metal on tang, but perhaps there is another fix?
