umm, only if...
Umm... they both actually have failed.
Most probably there is no fluid. check the level in the reservoir and fill as needed. Stroke the clutch pedal and bleed the slave cylinder.
there are other (less probable) causes, but with as little info as provided, a simple response is most appropriate.
