Chris, what would be a reasonable price? I am honestly not sure of the value.. open to offers
Hi,
Is $2,500 reasonable? Too much?
Thanks for the feedback. That’s why i put a question mark on the price. I know very little about these diffs.could be to be really reasonable if it is checked and/or renewed (better if)
i know that they are very few of these available, so it might be
for a " just removed from the car " it might be a little high,
but, hey, who am i to judge ? your price...your rules
Hello my friend, I am not mechanic to understand is this LSD can be install on the E9 if yes how much do you want for it and where are you located since it is very heavy to sheep it will be very expensive1971 E3 Diff is up for sale because I am swapping in an e28 rear subframe.
“S” paint on case:
Spindle stamped “S40”
Hello my friend,1971 E3 Diff is up for sale because I am swapping in an e28 rear subframe.
“S” paint on case:
you'll need to weld some rear subframe tabs if you want to keep the sway bar ,if you trim the e9 brake cable tubing it will slide into the e28 control arm ,just the tubing not the cable, then for the differential mount you'll just need a flat piece of steel 1\4 thick and drill holes match with e9 mounts then while the e28 diff and diff mount are installed mark for the new holes on the 1\4 piece of metal drill them and bolt it up , good idea to reinforce this area while your there at the stock rear subframe mount area on an e9 is weak and can rip off upon hard accelerationHello my friend,
will you explain benefit of E28 sub frame swap, since I have a complete car E28 I buy the E28 for the engine to swap the engine with my 72 2800cs how difficult is it to swap the sub frame, if it is easy fit I like to do it for my 2800cs all I need little explanation, please explain
thank you in advance
Shipping is cheap with "Parcel Monkey"
Just sent a tranny (125 lbs) from NY to SFO and it was $125
Fedex, wanted $425. Your conclusion.
Regards, Alberto
Me too, that was my $395!What happened to FedEx?
May package 130.00
July same package 395.00
I’m done…
FedEx probably had to raise prices because looking for lost packages is expensive.What happened to FedEx?
May package 130.00
I’m done…
