Hi Folks,
I have the three piece manifold that came with my redline weber kit. Also included are the studs and nuts. The manifold is unused. I’m not exactly sure why, but one if the intake runners doesn’t have a hump. There are no signs of grinding and “hump” is written on the mating surface. If I were to keep this manifold I would actually need to grind off the other 5 humps to port match my head, but your head may differ.
Another thing to note. The thermostat housing will need to be modified to clear the carb (depending on yours carbs). This is par for the course for most manifolds, but you probably knew that already.
I’m asking $100 shipped to anywhere (Hopefully not Australia
) Thanks for looking!
