I drove my coupe about 40 miles the other day, some stopping at signal lights and some on the freeway. About halfway through I noticed the brake pedal was engaging HIGHER than it normally does and by the time I got back to my shop it was engaging right at the top. Fluid levels are fine and no obvious problems were visible. It sat for about ten minutes before I drove it home and the pedal was still at the top. My drive home was only about 8-9 miles and it made it home with the engagement point still high but the brake function never gave me a problem. The brakes work normal except for the high engage point.
I haven't had a chance to check it since but thought I'd ask if anyone else has experienced this before.
FYI, within the last six months I went through (cleaned up) all four calipers and replaced all the rubber hoses. I've only put about 200 miles on it since then. I'm thinking some kind of vacuum/booster problem or master cylinder acting weird.
