Spare wheel size options
David
34.138016, -117.214714
I'm looking at getting a spare wheel for my car (I don’t have one). Im assuming a 7x14 (205/70) Alpina will fit in the trunk without mods, but what about a 7x16 Alpina (205/50) ?
TIA
Cant seem to find the answer in old posts...thought for sure this would have been previously answered.
Since it is no wider than the 205 on a 7x14 and since the outer diameter is similar or equal, it should fit into to space in the trunk without any problem
Does anyone happen to know what the factory rim and tire specs are ? Or, has anyone managed to fit a 7x16 spare in the well ?
Since the stock tire size on mine was 195/70x14, I suspect anything wider (e.g. 205) is likely to prevent the trunk floor panel from fitting properly.
Charlie
'74 3.0CS
correct wheel size for trunk
the posting just above is correct if you want the trunk boards to fit as they are designed
