budgerian
The car is starting to annoy me now..
As posted in a previous thread, I changed out all the wear items on the ignition and reset the timing. initial timing at tdc, as per manual. dynamic timing at 22degrees btdc at 2500 revs again as per manual.
The car ran like crap before, like not firing on all six, right from the moment I got her home after buying it, hence the ignition tune up. After renewal of parts and resetting the timing the car still runs like crap, got worse after driving it a few miles. Pulling the plugs on cilinder 5 and 6 simultaniously doesn't change idle, so both are not playing along. Pulled the plugs and here I got lost: not one (new) spark plug looks the same (see picture)
6 is wet with discolouration on bridge going almost towards the threaded part (which would indicate too much timing, which is odd, as the car runs on LPG, so it should actualy be able to go with MORE advance) and the porcelain is brown. Half of the tiny ridge on the top of the porcelain is gone, indicating preignition or detonation.
5 looks textbook perfect, heat travel on bridge ends nicely on the 90 degree bend, porcelain is white.
4 looks identical.
3 looks goodish, but heat travel on bridge goes all the way, again indication too much advance.
there is an oil film below the threads, so outside the combustion chamber
2 is oily wet. 1/4 of porcelian is brown, rest is white. heat travel as 3, all the way down the bridge. again oily film on part below the threads. look closely and you'll see the film on the right. the film does not go circular however, just one side of the plug, same as plug no 3.
1 looks unused like out of the box, bridge is still silver with slight heat travel which ends before the bend of the bridge, porcelian is bright white. plug is completely dry.
Before all of this I did a compression test, which was good, as in excellent. This was the reason I deemed the engine usable and started working on getting it going.
Before, I also adjusted all the valves to .30. No problems there either, all valves could be set within spec.
So, while I can read plugs just fine, I can not explain, why I got almost six different readings, some of them not spelling good news. However compression was good and valves could be adjusted, basically ruling out leaky stems and worn rings, or a burned or sticking valve.
Cooling fluid looks good, though not tested yet, temperature readings were and are ok, but before pulling plugs engine felt extremely hot, taking into account I drove less than half a mile.
Car runs equally bad on gas and LPG, which sort of rules out mixture problems.
Timing issues would not explain six different plugs right?
I'm sure my explanation leaves something to be desired, so fire away any questions, that might lead to an answer that helps me solve my woes...
Roger
4 looks identical.
Roger
