howdy all,
Need some help determining why my speedo lights don't work. Flasher indicator works, but cannot get speedo lit. All other gauge lites work.
Bulbs look good/clear/clean, even replaced/tried a different speedo, but get same results.....dark.
I wish the ol' stock dash VDOs were as bright as my new VDOs... :shock:
Can I change bulb watts?? Gotta good source for bulbs?
Also, how do you tell if the clock is really dead, tried two different units, can't get them to work (light works). Is this a direct wire to the battery or ??? Bizarre ground set-up?????or just take them out for skeet practice....(ie: quartz conversion)
TIA!
-shanon
'70 2800cs
TIA!
-shanon
'70 2800cs
