Squeaking clutch pedal
There are some plastic bushings at the pivot point of the pedal. When I rebuilt the clutch cylinder I went ahead and replaced these, it's easy to do, I also coated them in moly grease. Other possibilities are where the spring attaches or sticky linkage. Those can be cleaned and greased.
Had a squecking clutch pedal for years. Most likely the return spring scratching in it´s pivot point in the pedal. Tried many remedies, non worked. Ignored it from then on. Now it´s gone and I can´t even say since when..
