After a couple years of being very annoyed with a gremlin squeaking noise, especially when cold, I have determined today that it is coming from #1 cylinder. It's not the exhaust pipes or manifold connections, they are tight and I even loosened the down pipes to see if that changed anything which it did not.
I was about to give up when I decided to start pulling plugs on each cylinder, when I pulled #1 plug the noise stopped. It is not very perceptible when warm but quite noisy when cold. It only squeaks from idle to about 1500 rpm then goes away. The engine runs great otherwise and there is no noise when driving through the gears or under load.
Here is a video with me pulling the plug, the noise is barely loud enough to capture, but if you watch towards the end after I pull #2 plug you can hear the squeak/chirp a little better.
Any suggestions as to a fix or an I looking at major surgury? I can try a better video when the engine is cold if that is helpful.
(EDIT: I posted a better video later in this thread)
Thanks.
https://www.youtube.com/watch?v=NWghkBgIqNw&feature=youtu.be
Thanks.
