I read through the other responses and generally agree with all of them. However, if you cannot see or smell a leak near the carb bowl/s or the accelerator pump diaphram/s, why not confirm the existence of disappearing fuel. As someone else noted, open the throttle and you should see a stream of gas squirt from the accelerator tube down the primary venturi of each carb. Or, you could simply remove the top of one or both carbs and see what's what? Six flat head screws and one e clip that retains the choke rod per carb - is all that is keeping you from this.
The fact that you mention your use of starting fluid makes me think something else is your problem.
How are your chokes? Chokes and choke linkages do wear and occasionally require a little attention. (If I am not mistaken half of the spray cans that used to be on the walls of the auto stores were labeled "Carb and Choke Cleaner.") Whether your chokes are electrically controlled or heated by engine coolant, those flaps should be shut if the engine is cold when you crank it over. If the ambient temperature at Wright Pat is in line with late fall temperatures, the operation of those chokes is even more important.
Another possibility, albeit not the most likely, is worn throttle shafts. Weber 32/36's are notorious for wear there and this becomes a source for vacuum leaks. This could contribute to any poorly adjusted or partially functioning chokes.
If you can confirm that you actually have a lack-of-fuel problem, another possibility is that your float levels are set too low so that you are only filling the bowls minimally. This can also occur when the floats themselves develop leaks and absorb some fuel and - wait for it, - no longer float.
Returning to your use of starting fluid. Starter fluid works for all sorts of conditions from weak mixtures (lack of fuel) to overrich situations and - when your ignition system is weak and you are producing an inadequate spark. What is the state of your ignition system? Battery? How long since the last tune up? Coil? Condenser? Any and all of these things could contribute to hard starting when cold. The fact that it doesn't seem to happen overnight but after two days of sitting would seem to point to fuel, but strange things can happen - especially if your car is close to hangar 18! :wink:
hth and good luck!
hth
