taylorcom
Hi all,
I've had my '72 3.0CS coupe since '85 and from time to time as I drive, the throttle has refused to fall back to idle speed when I release the gas pedal. It tends to stick at the 2K-plus rpm level, UNLESS I quickly gun the motor to about 3K rpms. After I gun the motor, the rpm' s fall back to where they should be (around 1K at idle).
This symptom has occurred intermittently over the years and the solution has always been to spray carburator/throttle cleaner all over the carburator linkage.
Unfortunately, this easy fix has stopped working and I've been forced to attach a strong spring to the throttle linkage (on the driver's side of the motor) to keep the revs down. This solution works fairly well (I used the same technique on a '71 Triumph TR-6 that had a similar issue). But the spring makes the coupe's gas pedal very stiff and is not a permanent fix.
Does anyone have ideas on fixing this symptom, or any prior experience?
I'd rather not rebuild the carburetors, of course, unless I have to. The car runs smoothly, btw.
Thanks,
Steve
Thanks,
Steve
