acat2002
Busy sorting out some minor issues with an otherwise great coupe.
The first thing I must do is resolve this clunking noise from right front strut. Only occurs over small bumps (and not on the compression).
Took the wheel off and noticed some significant play in the top of the strut (not the strut mounting plate with three bolts - that is secure), but the roller bearing and bearing race that you can see when you take off the rubber cover at the top of the strut. (see photo)
Both struts themselves are new (within past year and w/ relatively no mileage).
The underlying question is this.......can this top bearing be replaced without disassmbling the strut completely?
Or could the large center bolt need to be tightened more?
Has anyone run into this? could you solve it without dissassembling the entire strut?
[/img]http://www.flickr.com/photos/26376951@N06/2472960778/
http://www.flickr.com/photos/26376951@N06/2472960568/
