I have finished my under carraige projects (a/c drain hole upgrade, new tranny seals, new center bearing, caliper/exhaust/manifold painting, and some frame/differential detailing) and want to clean up the clutch slave before tranny reinstall but it is frozen on the bell housing - what's the trick here - wood piece and hammer or some other barbaric technique? It didn't respond to my first overtures with the hammer so before I pull out bigger weapons I ask here. Also, the rod that pushes the clutch fork came out, is this supposed to happen or does it mean it's shot inside? Thanks.
