When you go to put the manifold back on you will know why studs are preferred. The studs will automatically locate both the gasket and the manifold. It is very difficult to do with bolts. The gasket shifts. does not line up, etc...
Ran gives good advice about the copper nuts. Technically the same holds true with nylon locking nuts, use them once and then replace.
I agree with the wisdom of using CU based nuts with steel studs and the fact that assembly is easier with studs. (Same reason some prefer lug nuts to lug bolts when installing wheels). In addition to any favorable chemistry presented by the copper alloy/steel combination, the copper nuts are designed with a gap that crushes against the threads, making it "self locking," or at least not requiring a lock washer. Nevertheless, other manufacturers and respected engine builders have successfully used all sorts of steel-on-steel fasteners to secure exhaust parts. An appropriately placed dab of antiseize paste, a lock washer, or even stainless fittings can be worthy alternatives.
I haven't given this issue much thought, but I far from certain BMW
always used the copper alloy nuts for exhaust manifold. And - if given the right circumstances, removal of a soft rounded copper nut can still be annoying if not unpleasant.
More to the point of the original post, I have seen the use of
bolts, in limited circumstances, to speed the process of manifold removal, especially when using custom parts (big headers) or where there are other interference issues. If one leaves a steel nut to bond itself to the stud, it becomes a
defacto bolt and theoretically reusable as such. Not a recommended procedure for the reasons stated. If you were using "square stove bolts" on old cast iron machinery pre-modified with bailing wire, I won't tell - but the exhaust leak may be a giveaway and even scare off unwanted varmints. :lol:
Other lesser considerations for using studs versus bolts is the fact that the cylinder head threads are aluminum and probably not the best material for repeated
over-torquing with small threads. The softer metal
generally loses in a tug-o-war with stronger metal. (Yes, I am aware that spark plugs are repeatedly torqued using the same materials and I am not saying it won't work). Secondarily, you risk an oil leak where the stud seals an oil passage.
hth :?:
