viphoto
Ok guys I need your collective knowledge to figure this out. Trying to figure out if my car has tuned springs or maybe just cut stock ones?.... Also will new bilstiens help cure excessive body roll?
Details :
1970 2800 cs
16 inch wheels 205 / 55 tires
26 mm front bar 22.55mm rear bar
KYB shocks
So I am trying to figure out if they also did the springs, which I would assume they would have done when they did the bars. Comparing my car to DeQuincey's suspension measurements in his post (see below) it seems like it did get some springs (but I did see a paint stripe on one which leads me to believe they may be cut original BMW ...Carl said they are no paint stripes on his...not sure about other kits). The car corners great but the body roll seems pretty substantial. Planning on installing new bilstiens but wondering if a set La Jolla springs would be worth the investment. I have to disclose I do have a warped sense of what is acceptable body roll after driving my 308 GTB recently...(apples to oranges I know and a decade newer car) but the coupe is such a joy to drive and would be more so with out the excessive body roll.
I saw DeQuincey's post http://www.e9coupe.com/forum/thread...all-and-not-so-small-bits-around.14519/page-5
It's post #86
I did the same measurements and came pretty close to his numbers for the "After" version which leads me to believe that the car was lowered....
My Measurements
Center of wheel to bottom lip of fender F 13 5/8ths" R 14 1/8th"
Top of tire to bottom lip of fender F 1" R 1 1/4th "
Any input from those of you that have been down this road is appreciated.
Details :
1970 2800 cs
KYB shocks
It's post #86
My Measurements
