Tail light help
kasbatts
Auckland, New Zealand
Hi team
just rebuilding the tail lights and re installing, can anyone help with a couple of things
1st is the wiring, I dident label this when I pulled it apart (stupid) and because of wiring issues
further up stream I cant meter it out
I have the earth wire and the tail light wire sorted, but dont know which way round the last two wires go, one is the indicator/turn signal and the other is the reverse light, both blue (one has a stripe on it)
and 2nd question is which of the two bulbs is the brake light and which is the tail light,
one has a metal reflector and the other has a plastic reflector (I think the brake light has the metal reflector)
Thanks for your help in advance
Steve
Steve,
Starting from the outside corner:
Turn signal - blue w/red stripe
Tail light - grey w/yellow stripe
Brake light - green w/red stripe
Reverse light - blue w/white stripe
This is on a 1972 CS US version. It also matches my wiring diagram. I assume you have one?
Champion!!
Thanks for that, answers both questions, and yes I do have a wiring diagram (now) found it about an hour after I posted..Doh!
Steve
