Tail Light Wiring
kys911t
So Cal
Im currently thing to get some of the wiring reconnected to my tail lights. I figured out the wiring based on the wiring diagram. However I have two loose wires. A Brown and a Grey that I can not figure out where the go to. I also have a similar Brown wire on the opposite tail light that has no home. Anyone know where they go?
  • Grey:Brown Tail Sm.jpg
have you found the wires for the sidemarkers? one is brown, the other is gray / red ... same wires feed the license plate lights. there is also a brown wire + a gray / violet for the rear fog light.
Us car. No fogs. Solid grey I think will check when I get home. Also solid brown that I think is a ground. Do the tail lights have a grounding point? I do not see one on it. There is a long metal thin bar that I do not know what it is for.
grounding
Yes each tail light has a ground tab to connect the brown wire to. It is inside near the middle (not along the edge with the others).
