Rek
I have spliced the engine harness from the E34 Alpina B10 into my car. Everything works (eventually) except the temperature gauge and fuel gauge. The fuel gauge I can discount from haveing a faulty sender.
The Temperature gauge is a different matter.
Earth the Brown and White gauge wire produces the full effect, so not the gauge. The sender was not sending any signals on resistance test so that was replaced.
My sender has two wires coming from it. One brown and yellow and one brown and violet. My diagram says the brown and violet has the resistance and the other goes to earth, however SFDon whom I would trust above all else says the brown and yellow should be connected to the dash gauge.
I've tried both and nothing works. The fit of the sender wires is not great but there is continuity in the wires and a connection.
Does anyone have any ideas which might help? I am shaking down the car after a rebuild and can't afford an overheating engine.
