execmalibu
- Messages
- 629
- Reaction score
- 2
There are some of you guys that think I am buying everything E9 that is offered for sale just to "HOARD" the stuff... That is NOT the case! As Scott pointed out I have (5) E9s and ALL are different a 1970 2800CS, a 1972 3.0CS plus a CSi, a 1973 3.0CS, and a 1974 3.0CS
Let me explain to you a few things that you do NOT know. Although the parts I buy may look good, allot of the parts when I get them are in just fair condition. So if I buy a pair of center console side panels and one has drama I will have try to find another pair to buy to hopefully get a nice set... If the second pair also has drama I will be forced to buy a third pair. You guys will think I am buying every set just to hoard them which is NOT true. Plus there are two types of side panels AC and Non AC... Four of my E9s have AC the CSi does NOT have AC.
And what you guys also do not understand that these E9 parts are NOT all the SAME! The Chrome Bumpers are different, Bumper Guards are different, the Trunk Panels are cut differently from year to year with three different types, There are three different Lower Dash Knee Bars that are NOT interchangeable, There are three different types of under dash panels! There are three different Turn Signal Switches, The Gauges are different, The Overflow Tanks are different, The Steering Wheels are different with 7-8 different types, The Window Motors are different etc etc... Then the CSi has lots of parts that are totally unique to a CSi...
How many of you know that ABSOLUTELY NOTHING in the 1974 E9 interior is the same as the previous E9s? Not one thing is the same! The Seats, Door Panels, Dash, Window Switches, Steering Column, Turn Signal Switch are unique and are ALL 1974 ONLY!!! I will bet that you never knew that the 1974 E9 has a Telescoping Steering Column or that the Turn Signal Switch is on the left side or that the Access Door for the Hood Release Turns instead of having a Button... It is NOT just the Bumpers that are Unique the 1974 E9 has tons of other 1974 ONLY parts... It is like a different Model E9 an E9B... Again when you see me buying lots of parts it is often because the last part I bought was not that nice or did NOT work or does NOT fit!
A few weeks ago the Alternator light came on in my 2800CS... I could have removed the Alternator driven to the rebuilders shop waited a few days and driven back but that did NOT happen... I know Old Cars and had the foresight to plan ahead and I had a spare Alternator on the shelf and the car was fixed in 30 minutes... I also have a spare Starter,Distributor, Window Switches, Relays, Turn Signal Switches and other misc. electrical parts that often fail on Old Cars... Plus because Erik at Coupeking told me that D-Jet Injection is prone to Injector/ECU Brain failures and he also said that D-Jet parts are impossible to find. So following his advice I bought a COMPLETE spare CSi Injection system (Brain, Wiring Loom ,Fuel Tank, Injectors, CSi Distributor, Throttle Body Etc Etc) Just so I am covered when the SH!T hits the fan... It is sure nice to be able to open a box and pull out a good used part when you are unexpectedly forced to NEED one.
The interior in the Great Pumpkin was in excellent condition EXCEPT for the left side of the Center Console was all torn up like they tend to be. Yesterday I took the dash apart and replaced the left side with one I had that was much better and only had a tiny flaw that I repaired... I saw that the underdash panel was torn up so I replaced that also. Was I glad that I had planned ahead and bought a few spare parts that are known to have drama... In a word... YES! Now the interior in the Great Pumpkin is nearly PERFECT...
Is this "HOARDING" or is it being prepared with (5) E9s for the inevitable?
