I just rebuilt the twin Zeniths on my 2800CS and attempted to perform the carb balancing process. The car now has an annoying “jerkiness” to the throttle when going from off throttle to on throttle. Example: Coasting in 4th gear, I hit the gas to accelerate past someone—the engine hesitates (bogs) then abruptly accelerates. Another case: downshift to 2nd so that I can make a 90 deg. right-hand turn—after making turn in 2nd I hit the gas, engine hesitates and then abruptly starts to accelerate. Throttle is not “linear” like it was before the rebuild.
I performed the synchronization using 2 Mityvac vacuum gauges. Per blue book, carbs seem spot-on balanced at 1700 RPM, with both gauges showing 20 mm HG. Exhaust CO is 2.5 % per my Gunston gas analyzer. Idle balancing was trickier because both vacuum needles fluctuated around 17 mm HG—due perhaps to leaking valves. Timing, dwell, and valve clearance are to spec.
Question to the experts is whether this throttle jerkiness is because of a carb imbalance or rich / lean mixture issue?
Thanks for any inputs -H
