The problem is that a cable system uses a pulling motion and the E9 is set up to do a pushing motion (hope this makes sense). I had that situation when installing the M6 engine in TBL. The throttle on the M requires pulling and I was just about to invent some Rube Goldberg kind of thingie where I would tie a string between the engine and my hand but then every time I scratched my head...well, you get the idea. Then, just in time, the former owner of the shop where I used to rent space came up with a brilliant solution. I won't bore you with the details but is was simple and yet so insightful.
