Throttle linkage.
e9john
Rochdale, UK.
Has anybody got a photo or can explain how the throttle linkage goes together on a right hand drive car, mainly the orientation between the pedal-linkage rod-accelerator bar, everything I've found is for left hand drive cars that have a different set up.
Unfortunately nothing was marked up or photographed when it was taken apart.
Thanks.
John.
Hi John, i should be able to get you these pics tonight - do you mean in the car at the pedal end or going along the firewall?
Throttle
Thanks.
John.
If you want to come and look at my car so you can take as many photos as you want just drop me a PM.
30csl - I'm after the position of the lever from the pedal box in relation to the accelerator cross bar and the position of the lever arm on the carb side in relation to the other end if that makes any sense. I'm presuming the carb lever points down at 6 o'clock but need to know what position the flat bar that comes off the accelerator bar is in relation to it. I have nothing at the moment and don't know where to start setting it all up.
Simufly - thanks for the offer, if I can't figure it out from the photos I'll pm you.
Cheers
John.
Hi John, if you send me a text/whatsapp tonight 07793 563 281 i will get this but my car is injected not carbed - will that work?
