echappe
I finally have my car back after 3.5 M30B35 swap with new 38/38'S. The carbs weren't even close to what is advertised as off the shelf jetting. All is well now with correct jetting and proper adjustments made with wide band air fuel analyzer. Car hauls A__ , now the only issue is there is a point of force required to get the acclerator pedal off of idle position, after which too much pressure is exerted causing whiplash effect. Has anyone dealt with this issue by installing a spring somewhere in the linkage to counteract this inertia?
Thanks in advance for your assistance,
Ernest
Ernest
