So I have a bit of a head scratcher:
74 w/002 Distributor (both vacuum advance & retard) with a Pertronix Ignitor.
I was setting the timing today and while at it doing some basic maintenance to the distributor. However, it appears my vacuum advance is not working. With the engine stopped and cap off, I can see the armature moving when vacuum is applied. However, applying vacuum while the engine is running produces no change in base timing.
I thought vacuum advance failures were almost always the result of a bad diaphragm. In my case, the armature moves, which would indicate the diaphragm is fine, correct? If the plate/ignitor is moving in response to the armature, how can the timing not be effected?
Thanks!
-Lloyd
Thanks!
-Lloyd
