sdoyle
- Messages
- 66
- Reaction score
- 15
I have just installed a re-bult engine in a E9 3.0 CSA, the autobox was not touched, it has only 40K miles. At first it seemed ok. After a short time, hours, a very loud metallic banging began from the the torque converter / bellhousing area, but only at low revs. When revs increase the noise stops. I have removed the the bottom metal acess plate and plastic cover. The bolts connecting the flywheel and torque converter are tight, it seems as the fly wheel is tight on the crank shaft. I cant see anything wrong, there are no marks on the torque converter / flywheel. With the engine running and banging in progress I can feel a roughness as if something is hitting something else.
Before I remove the gearbox does anyone have any suggestions.
Thank you
Sean.
Thank you
Sean.
