Hi, my car is not starting, initially when I had this problem I would put forward pressure on the gear shifter in Park, autobox (BW), and it would start. Now I could bend the shifter forward and it will not, (it will not start even in N) I have swapped the start relay with no luck, unless the swapped used relay was bad also. I am guessing it’s the shift selector unit (dark silver/grey color) that is installed on the tranny itself.
Question, does the shifter rod attach to yet another selector right under the center counsel? Not sure if my memory is playing tricks, for some reason I’m thinking there is another unit there (black in color). I don’t want to start removing thing just to find out. Second, does anyone have a used selector (the one that attaches to the tranny), mostly to those who have swapped their auto to 5spd. Thanks.
