transmission 3.0cs 1972
Larry,
I am no expert, but if you are finding that shifting gets tougher and difficult to find the gear you are looking for, you may need a new clutch soon. Check the fluid reservoir to see if the levels are correct or being depleted as well.
Right. The first thing I would is bleed and adjust the clutch. If the clutch isn't disengaging the transmission from the engine all the way - then it won't go into first.
HTH
James
