I am going to drop the tranny this weekend to replace the rear seal and shifter bushings, and inspect/improve the A/C drain hole before the summer season. the manual says I will have to mess with the clips around the shaft/release bearing. Is there something I need to look out for here or does it pull (slowly) straight out? Anything else to check out while I have it on the bench? Thanks.
Pull out gearbox slightly.
Lift spring over spherical pin collar.
When installing: Angular seal (1) must be between spheri-
cal pin and throwout arm.
Inside clutch operating mechanism:
When installing: Move throwout arm to correct position
with slave cylinder. Align throwout bearing. Grease guide
sleeve and groove in throwout bearing with Longterm 2.
Select a gear before attaching gearbox.
Carefully insert gearbox guide sleeve into thrust bearing.
Turn the output flange until the input shaft slides into the
driving plate. Remove the clutch slave cylinder again.
Fasten the gearbox into position.
