Transmission(s) for sale 5-speed
Peter Coomaraswamy
Austin, TX
CLEAN TRANS IS SOLD
Dirty one is still available-
Hi Folks, I think these are g-260's and I don't know if they are worth anything to to the folks here but thought i would post. They are both 5-speeds but I don't think they bolt up to the e9 easily or the 2002. I figure 250.00 plus shipping each?
It appears that the "cleaner" gearbox is a 260/6 that would have been found in an 86-88 M30 car. The Motronic sensor mounting bosses and aluminum shift console mounting tabs should confirm this. It will bolt up to any M30 however depending which version, specifically the oil pan, the lower flywheel cover arrangement may be different. I believe the bellhousing pattern suits the M10 as well but not positive on that fitment. The dirtier gearbox looks to be a 260/5 with an M20 bellhousing pattern (86-88), indicated by the shallower starter mounting holes and extra thickness of material along the top of the case where it bolts to the block just below the head. Shift linkage assemblies will be specific to whichever chassis you want to install these into, and could require some fab work. Additional info on the gearboxes here.
