Triple Weber for E3 2800
I have a set of Spanish Weber DCOE 151s. I had these on my 3.0 CS, but when I changed to the DCOMs I took some of the calibrated parts from these carbs so you would need to go through the entire setup before installing them on your car.
We have multiple sets of the DCOE carbs, both Spanish and Italian, the side draft manifolds and, of course, our original side draft linkage system for the M30. We also carry the manifold to carb isolator spacers with gaskets and 11mm wrench brass nuts to help with the install. You'll also need a offset spacer for the coolant divider to clear the carbs and we have those. If you need a smaller diameter brake booster to help the air cleaner fitment, we have those also. In short, we have anything required to convert to side drafts! Here are some pics and links to relevant web pages on our site.
Hi
I wonder if someone can direct me to where I can purchase one of these thermostat housing spacers?
for a triple carburetor conversion.
Shaun
Here ya go!
