sreams
My CS has been running great for several months now, ever since I put in the M30B35 and tuned the Weber DGEVs with it. Idle is butter smooth. I installed the Pertronix Ignitor kit (which I've used on several cars in the past), and that, along with setting the proper spark plug gap, has resulted in a smooth and even idle that is predictable. It has been 100% consistent until today.
I went to have my air conditioning system charged for the first time in years. I have a York compressor and an early aftermarket Frigette system (aftermarket condensor and evaporator). The system took the R12 fine and appears to have no leaks... although the York compressor is now sounding a bit noisy (didn't hear this when running it before the recharge)... so my plan in the near future is to recover the R12 and replace the compressor.
That said, the strangest thing has been happening today following the AC recharge. I was on the way home using the newly charged AC, and suddenly the idle became rough and dropped to about 300-400rpm. I turned off the AC, and the idle was still rough and far too low. I got home, and could clearly hear from the exhaust note that there was a seemingly random miss. I spent the next several hours trying other coils, trying other spark plug wires, testing voltages, etc... and nothing seemed to have any effect. I then started pulling plug wires too see if it was limited to particular cylinders. At this point, for no reason that I can comprehend, everything started working perfectly again. I then spent the next hour just getting my idle mixture and idle speed back to where it was (I had messed with it a bit before I identified the problem as a miss). Again, the car ran perfectly. A night and day improvement. I turned the AC on for a few seconds and then off... and immediately the problems started again. The bad miss had returned which resulted in a horribly rough idle and popping from the exhaust.
Frankly, unless there is some -very- funky wiring, I don't see how the AC system could have any effect on the ignition system. Anybody want to give it a best guess?
-Scott
-Scott
