Dohn
My turn signals do not self-cancel on my '74 CS. Was told there is a disk in the steering column that makes that happen, but it hasn't bothered me enough to fix. But now I've added the issue of the turn signal lever (left side on the '74) not holding place when engaged, forcing me to hold it in place when signaling. In addition, if the headlights are on, using the lever sometimes causes the high beams to flash erratically, which is annoying to all. W&N still carries the replacement stalk for this model, and I will buy one, but wonder if both problems could be in the lever, or if I still need the disk.
