Today I noticed that when I had the turn signal in the on position (either left or right, made no difference) and the motor off, key removed the frint side marker light was on and the rear tail light. Lights were off. Not flashing, just on. Typical?
German or european parking lights, I have been told, used for added safety/visibility when the car is parked. Either side can be lit up with turn signal.
Pretty neat actually. If you're parked in a row of cars on the side of the road you can switch on the parking lights on the left side only in order to make your car more visible to passing traffic
When I bought a CSi many years ago I remember being amazed that a 35 year old car has this feature .. German engineering, what more can I say
Yea, I guess this was a German or European requirement back when, and they installed it on US delivery cars as well.
Keep in mind that it will drain your battery if you forget to put the TS switch back to the center position when you park you car overnight. While I will agree that this feature is one of the charming quirks of the older German cars, some of that charm is diminished the next morning when the *&^&() car won't start.
Still do it on many modern BMW, VW, Mercedes and Audi cars
Used to be a legal requirement in the UK but I think it was dropped in the mid 1960's when reflective number (Licence) plates came in.
There are only two parts involved, the ignition switch (provides 12V to that circuit only when ignition is off) and the turn signal stalk (has dedicated contacts to pass that 12V to either fuse 1 or fuse 3). From the fuses on all the wiring is common with your regular lights, so all that presumably works.
The easiest diagnosis is at the turn signal stalk connector because you can verify there that you get 12V, that the stalk contacts work, an also continuity to the fuses.
