Turn signal switch !974-75 cs csi csl LHD
de coupe
arizona
Hello,
Recently had to part with a 1974 csi. In clearing out the garage found a 1974-75 turn signal switch. I do have a 1973 and in need of a turn signal switch for that car. The turn signal switch is new never got installed found out that was not the problem still in bag from Max importers. I believe that I did pay upwards of three hundred dollor for the item. Its all a blurr now. I do need a a 73 switch Can we make a horse trade. If not I believe it would go for two hundred dollars... Thanks Daniel
Look in post below that I have for sale " NEW PARTS ADDED e9 & e24 Parts for Sale"
That is a used 73' turn signal switch.
9) Used Switch, p/n 61 31 1 355 322, good shape, only thing wrong
is when you use the right turn signal it will not spring back, you
have to move it to turn it off. Other wise it works. $75.00
Thanks,
