I have a couple of questions. I have a 1972 LH drive 3.0cs, the combination turn signal/wiper switch is on the right side of the steering column. You push the end of the stalk to turn the wipers on and off. The wiper switch on the end of the stalk appears to be stuck and will not move in and out, has anyone experienced this issue? Can you take the plastic tip off of the stalk, if so how?
The turn signal, wiper, dip switches changed in 1974 was the turn signal switch moved to the left side of the steering column at that point?
Thanks, Doug
Thanks, Doug
