acat2002
To the hard-core purist...try not to cringe when reading this.....but...I'm installing an aftermarket alarm/keyless entry because I actually plan on using my coupe on more than just a sunny weekend
This probably has a simple answer, but where is correct place to connect the "side marker indicator" - i.e. the one wire that will illuminate all four corner turnsignals when the system is 'armed'? The alarm control unit sends out two short positive pulses through this wire to let the user know the system is armed/disarmed by blinking the turn signal lenses.
I'd assume it would be one of the wires coming from the hazard relay, or hazard switch? I have the "blue books" with wiring diagrams as well as the Prosperos laminated wiring diagrams, so I'm not completely in the dark.
In any event, I wouldn't trust my coupe to the local audio/alarm geeks (hacks). Also, my coupe is stripped out awaiting new interior & dash, so I'm stuck doing this myself.
Any advice would be appreciated - thanks.
