Malc said:Assume you mean the thread size for the plugs - yes it's 14mm You can get a chasing tap at any good automotive store, along with a suitable plug spanner (box wrench)
Looking from the rear of the car the FI ECU is situated under the rear RHS seat fastened to three lugs. The fuel pump relay is usually nearby
HTH
Malc
Bill Riblett said:I'll have to double check, but I think I just use a common 13/16th plug socket. Whatever, it is a lot bigger than 14mm.
chicane said:Malc said:Assume you mean the thread size for the plugs - yes it's 14mm You can get a chasing tap at any good automotive store, along with a suitable plug spanner (box wrench)
HTH
Malc
No, I meant the actual socket wrench size for the plug. So you are saying under the rear seat on the right hand side?
Gosch said:The correct size is 20,8mm Metric
