Are replacing head on a 2800cs. The head supposedly has the updated valve guides. But the seals we bought are too small.
Measuring the top of the valve guide where the seal goes is .425" which is roughly 10.8mm.
Here is a photo of three seals
The one on the left is what came is the gasket set. We think this is for the earlier valve guides on the original head. The top of those guides were we believe was 13.9mm. Part number for one seal is 11-34-1-261-269.
The center seal was an old one removed from our replacement head.
The one on the right is from a set we ordered from that is suppose to be the updated style, The part number ordered was 11-34-9-059-172. Obviously they are not going to fit. The OD is .482". The ID is .370".
The OD of the removed seal is .505, ID, the ID slightly less than .425 for a tight fit over guide sealing with the rubber inside.
The valve stems are .482" and the top openings of the new seals are much smaller than the removed seal. Can hardly fit the valve into the seal on the work bench.
Where can we get the correct seals? What is the part number?
Can anyone help with the correct item source?
jjs2800cs
jjs2800cs
