do not think is so relevant,
it is true, oil gets thinner when hot and pressure decreases, but all that has been considered in the design of the oils
my banjo bolts are in their place secured with loctite and Steel wire
i must admit that valve tappet clearance is not what I thought,....or maybe i am wrong
I do not think anyone is disputing the fact that metal expands with heat and that the valve lash or tappet clearances get smaller as the various metal components expand. However, I was just trying to offer an explanation for why you seem to notice more engine noise from a hot engine than a cold engine. Engine lubrication may seem simple, but it is a complicated subject involving words that are difficult for me to spell let alone explain, e.g., hydrodynamics and elastohydrodynamics.
After an engine is run hard, it often sounds different than when cold. Some of the parts can be starving for oil, especially when engine speed is reduced to idle and, correlatively, when oil pressure is also reduced. This is one of the reasons for cool down laps or running an engine at fast idle prior to shut down. Oil pressure is significant as it both cushions and lubricates moving parts as well as removes heat, and oil exhibits different characteristics with temperature, including viscosity/thickness and flow. Of course, parts are designed to incorporate working tolerances, but different parts and different metal compositions expand at different rates relative to different temperatures. So, even though valve to rocker clearances are smaller when the engine heats up, the characteristics of the oil in your engine may not provide the same - boundary lubrication, cushion, flow, resistance and/or metal-to-metal protection - as when cold. Less "cushion" or protection between reciprocating metal parts generally results in more noise.
Multi-viscosity oils are supposed to retain or increase their viscosity when warm, but not all oils are the same, and not all machined moving parts are the same. In other words, when your engine is warm, even though the metal parts have expanded, the oil may not provide the same boundary lubrication that it provides when the engine is cold or when the engine is at speed and the oil is under significantly more pressure than at idle or slightly faster than idle. That so-called oil "cushion" functions to occupy greater clearances found in "worn" metal parts, that can contribute to valve train noise, e.g., worn rocker bushings or worn rocker shafts. It is also why heavier weight oil and engine viscosity treatments such as STP, or Wynn's Friction Proofing, Casite Motor Honey and the like, may result in a quieter running engine. Of course, quieter, may also mean reduced performance since thicker engine oils tend to create more parasitic drag between moving parts.
Different oils of the same viscosity can seem to contribute to different noises. An engine running clean, uncontaminated/undiluted, oil tends to make slightly different (less) noises (when at operating temperature) than dirty, contaminated, oil. More stable synthetic oil tend to flow better and offer greater metal-to-metal boundary lubrication than thicker conventional oils, but they are no substitute for large metal-to-metal clearances found in older engines and significantly worn engines
And no,
I am NOT advocating that your engine needs these oil additives or related products, - although the graphic decals on the side of your coupe would make an interesting statement.
"The Racer's Edge"
Not oil viscosity improvers, but may improve oil flow
Examples of properly set tappet clearances?
Improperly set valve lash?:eek:
