corsachili
Last week I finally got the rest of my doorseals on the driver's side of the car properly installed. Unfortunately, doing so brought forth an annoying whistle the makes its entry at 40MPH and gets only worse. Wind noise is something that you get used to on a CS, but whistling from that area is just unacceptable. It's ironic that it showed up AFTER I got the doorseal properly tucked in and installed, such is life.
I noticed that the chrome that surrounds the vent wing didn't look lined up properly in that it was actually hitting metal on metal at the top while there was a larger gap on the leading edge. Reluctantly I took the door apart in the hopes I'd find some way of adjusting it.
Talk about frustrating. Essentially I can see no way to adjust the door or the vent wing frame such that it will close up this air gap. The door seal is brand new by the way. There is some modicum of adjustment in and out, but essentially none fore and aft. I monkeyed around with it for hours, and even went so far as to remove it and install one from a spare door that I have, thinking perhaps this piece was bent. The spare part didn't do any better. I adjusted the door but the gap is as close as it can be without having the door hit the body (at the front).
I'm perplexed to say the least, and more than a little frustrated. I simply have no idea how to eliminate this gap. It's so bad that you can see through it when you're in teh car. The seal and vent wing frame are not even touching each other for about 4 or 5 inches along the leading edge. there is at least 2-3mm of gap between them. :cry:
As far as I know the only adjustment for the doors is on the hinges where they bolt to the doors. The hinge that is screwed to the body is not adjustable (at least I believe this to be true). There is no way that making the door close tighter will fix the problem either, and there are no shims between the hinge and the door (which you'd think might be the reason for that gap).
Anyone have any bright ideas?
