bengal taiga
- Messages
- 234
- Reaction score
- 32
This post seeks information regarding light wisps of smoke from the tailpipe- almost exclusively at idle. As explained in more detail, the smoke is not always visible but can be more pronounced as the engine heats up. A little background:
Per my recent posts, my pressure sending unit took ill and I managed to adapt other Djet parts to replace it, pending my finding a spare. I have since found my spare PSU and installed it. The engine seems slightly more tractable than with the other parts, but the fuel economy is not as good as with the replacement parts. (Down from 24 mpg to 21 mpg.) The engine was rebuilt about 6-7 years ago. Most of the fuel injection components are original, even the fuel injectors (although fitted them with new o-rings and feed tubes. I observed each injector to insure good even spray patterns.) With all of the idling, I noticed the temperature gauge started to creep near the red in traffic and this prompted me to replace the viscous fan clutch with one that engaged with less heat. The temperature gauge now sits at 3 O'clock.
Since all of the tinkering and considerable idling, I noticed that at idle, there are very light wisps of smoke emitted from the tailpipe. I have not noticed this before. It is hard to discern whether the smoke is whitish, bluish or dark gray. So far as I can tell, the smoke only appears at operating temperature or warmer. It is not noticeable upon acceleration, leading me to conclude it is probably not rings. I have tried heavy deceleration and do not notice any smoke either, leading me to exclude valve seals and/or guides. I have also rerouted the camcover vent tube to eliminate blowby as a source of the smoke so that it is in effect a downdraft tube. The receiving end of the intake manifold has been plugged. Blowby is very slight and hardly noticeable.
Pulling the plugs reveals five extremely clean plugs. One plug, out of number 4 cylinder, seems lightly darker than the others and seems shiny and almost wet. It is not fouled. Nor is it covered with oil burning deposits. It is NOT clean as one might find with a coolant leak due to a leaky head gasket.
To the best of my understanding, I am not loosing any brake fluid and the brake booster is dry. I am not loosing any coolant or engine oil. The coolant remains translucent and the oil is remarkably clean (no milkshake). Compression is 185 in all cylinders. I am currently using Mobile1 20-50W and valves have been adjusted to .011 Cold.
Given the above, I am scratching my head to deduce the cause of the smoke and remedy the situation. The one thing I haven't done is pull the fuel injectors to determine if one of more of them is either leaking or putting out an irregular amount of fuel. Since I did not detect any loss of brake fluid and notice that the master cylinder is dry, I see no reason to disconnect the brake booster vacuum hose.
Any constructive thoughts would be appreciated.
Thanks in advance.
Thanks in advance.
