Vintage Momo BMW horn buttons & hubs
JohnP_02
Ohio
Hi all, It appears I am more than a bit flush with these, so I guess I can let a few go. If you want a period correct look and feel to your coupe or other vintage BMW these are what you want. All original, authentic, the real deal 1st and 2nd gen Momo horn button in top notch condition, so not cheap but better than ebay prices. The hubs are all solid 152’s some with a horn pin some without (cheaper if not included). The 152 works very well with e9 and brass contact rings that will work for these may be available soon. Small discount if you buy a hub and horn button together. DM if interested please.
I have a Nardi Personal. So do these Momo buttons fit without having to get a new ring?
I don't see a picture of back side.
You can buy the thin metal button mount that has momo 70mm PCD holes along with Nardi 74mm PCD holes. They are cheap. Check crowder’s. Also they will be on ebay.
Like this:
Thanks Mark, yes, Nardi and Momo horn buttons are not interchangable really. Nardi are slightly larger in diameter, so you can use a Momo horn button with a Nardi wheel/hub you just need the retainer ring that Markos posted. It is quite common to do this actually.
This is what it looks like with a Momo horn button and a Personal (Nardi) wheel.
Hi, I have a Momo Moretti wheel that I would like to fit on my E9. Do you have the hub and horn ring that will fit this wheel?
My email: [email protected]
The 152 hub will work fine, but I do not currently have contact ring. You may be able to find one here on the forum or eBay however
I’m having the brass rings and ABS based cut via waterjet. A forum member is helping me out with the drawing. I’ve made them before by hand but the brass sheet kills my drill bits.
Update: horn buttons are off the table (I am keeping the rest for my personal use), but hubs are still available! DM if interested.
Thanks to all that have purchased some already! I also have some stickers I made if anyone is interested? $2 shipped CONUS for any two (All are 3" and window decals or regular stickers available!).
