'73 CS, stock. My headlights dim badly when the engine rpms drop to idle. Looking at the Autobook from www.cscoupe.org, it says "A simple test on alternator charging can be carried out after dark by switching on the headlamps and starting the engine. If the alternator is charging, the headlamps will brighten considerably as the system voltage rises from the nominal battery voltage to the higher figure produced by the alternator." Seriously???? This is NORMAL??? The ignition warning light does NOT stay on when the engine is running suggesting the regulator is working.
I should note that I have installed Daniel Stern relays in the headlamp circuit some years ago.
