W&N front floor panels
bavbob
Boston, Ma
The W&N front floor panel I bought for the driver's side ( same for both left and right) has the stamped portion centered and if you desire to place the stamped portion in the correct position, the panel is not wide enough to even cover the gas pedal, falls way short of the tunnel. Dissapointing. If you need the entire front floor panel replaced, this is not for you. Should have got the Mike Pelly panel instead.
Exactly correct....
W&N has good rear panels and Pelly has the right stuff for front.
