WANTED THE ALUM RAILS AT INSIDE BOTTOM OF DOOR OPENING
aearch
pleasant hill , ca
THE TWO TRIM THAT SITS ON THE BOTTOM DOOR JAMB
HOLDS DOWN THE CARPET
ILL POST TH PART NUMBER
IN A BIT
NEED ASAP
OK THANKS ALAN
I think they are stainless steel.
If you would like quick answers from the group, then pics/ numbers will help. I think you ar eloking for these:
I
do not have them, but they are available in germany:
Attached add shows the interior (longer ones) on the right side, and the trim that screws on the outside of the rubber trim is the short one (as it needs to fit between the A and B pillars.
Image from Walloth; (who do not seem to have them) : Item #14 is what Alen is looking for.:
Obviously you want the best you can buy...I have a pair of the long stainless trims (that Eric shows) that need a little edge straightening (second pic/close upalso same trim e9.JPGalso same trim.JPGe9 carpet trim long L&R.JPGsame trim.JPG, otherwise straight...need polish or good wool waxing.. no screws...what I'd call typical wear for $150+shipping (at cost.) I'm having deja vu...like this is a road I've been on before...
