Water chokes on a carbed M30B35?
sreams
Sacramento, CA
I've got my M30B35 almost ready to drop into the car. I'm going with dual Weber 32/36 with water chokes (for now). On the original motor, the coolant hose that feeds the water chokes comes from the front manifold, and the coolant return goes to a fitting on the block just below the #6 intake port. The B35 doesn't have this fitting. Any recommendations on how to route this hose? Thanks ahead.
-Scott
I recently went the same route and capped off the water and used electric chokes. IIRC if you want to use the water you need to drill and tap a hole in a water passage. someone correct me if I'm wrong
I think the electric chokes help clean-up the engine bay. Just too many hoses for me and now I don't have to worry about one giving out.
