I have found water pumps from different sources and they are manufactured by different companies. The two I like so far are made by HEPU and MEYLE. Both are made in Germany. Does anyone know if one is better than the other?
Speaking for myself, some brands may have had a less-than-sterling reputation, but I do not think this holds true any longer since pumps can likely be rebranded or manufactured by anyone and anywhere. A supplier you can trust (should the pump leak in a few days after installation) is probably a more important consideration nowadays. I noticed a few other brands that you did not mention "Bugati" and "Laso" but have no specific knowledge about them.
Fit and finish might be meaningful, yet appearances can be deceiving when it comes to pumps, since it is really only the bearing and seals (which you can't see) that are important. Some pumps use different impellers (Stamped steel vs. cast iron). This might make a difference in pump performance or even longevity but I really can't opine on that.
FWIW, the last pump I bought was a new Graf that had a rough appearance as though it had been rebuilt. I think it bore a stamp indicating Italy as the country of origin. No matter, since it has been working fine.
__________________________________
Perhaps this related question is deserving of its own thread. The following diagram indicates individual water pump components are available. ( Nos. 14, 15 and 16 are the most likely wear parts.) This causes me to wonder if anyone
successfully rebuilds their own pumps as was a common practice with water pumps for other cars -
many many years ago.
