nashvillecat
- Messages
- 123
- Reaction score
- 11
I have a waterpump that seems to work fine (engine runs cool) no leaking weep holes. Unfortunately, it is terribly noisy leaving me to conclude the bearing is going or gone.:cry: And no, the belts are not tight because I do not like to over-stress either the alternator, water pump or steering pump bearings. I have another pump that has been sitting on the shelf collecting dust. I believe it is a graf pump, but I cannot locate any markings on the housing. I no longer have the box in which it was originally packaged, but I know the other two pumps for other BMWs are grafs in graf blue/white boxes.
The never used on-the-shelf pump seems tight enough, but it appears to have some slight lateral movement when the nose is pushed and pulled sideways (on the axis of the pulley). Another thing that is of concern is the fact that this pump is noisy in the sense that the seal seems so tight that it has a slight low pitched squeal. I can state unequivocally that the other pumps on the shelf do not emit any noise and are tighter and do not offer the same lateral movement. Fortunately, replacing the pump on an M30 engine is not a day-long or terribly expensive process. Nevertheless, I do not like having to repeat the same work twice and I am cheap when it comes to flushing almost new antifreeze down the drain.
If anyone out there has a waterpump nearby or recently replaced their pump, perhaps you could offer some subjective observations about the play in the pump and any noises encountered. I am aware that not all pumps are the same and that some pumps may even be self-healing with a little wear and heat cycling. This unused pump will hold pressure via its weep holes (I have tested them) but that is no guarantee the pump won't fail from the beginning. After all, the currently installed pump works find despite being loose and not showing any signs of leaking.
Should I ignore the warning signs and try the pump? Or am I wasting my time?:?:
Thank you in advance.
