Bwana
Does anyone know of a source for the wave washer under the nut that backs up the door key tumbler assembly? Astonishingly enough, I found one that is almost the right inner and outer diameter at ACE Hardware of all places. Problem is, it's more than twice the thickness of the paper thing OEM part so the spring rate is probably high enough to pull the key chrome thru the door if tightened fully :eek:
Real OEM lists it as part of the key lock assembly so it's NLA. P/N 51211809928
